Thread: 3Rd brake light
View Single Post
Old 12-20-2012, 01:34 AM
Jaden78 Jaden78 is offline
Jaden78 is on a distinguished road
To remove the break light, first remove the the philips screws from the back side. This separates the light from a tension bar inside the spoiler that helps to maintain pressure against the weather seal. From there, you can use a putty knife or small screw driver to disengage the clips along the lower edge.
note, there is no quick disconnect at the light, unless you can find out the correct bulb size ahead of time, you may be doing this proceedure a few times to get the job done.
Check out this link to Subzero's install of a backup camera, it shows the light hanging out of the hole....good reference.
07 V6 SE | Bilstein 5100/FJ Swap @ .85 | VSC Override | Alpine INE-S920HD Nav w/ Rear Camera | Map Light Mod | LED Conversion | Bluetooth Integration | Bushing Upgrade | Heated Seat Conversion | Custom Console Organizer | AutoDim Mirror with Home Control | More to Come...
Jaden78 is offline   Reply With QuoteReply With Quote
