View Single Post
Old 03-17-2013, 01:59 PM
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
Originally Posted by philsey View Post
I used to live in the country and mice (rodents) were a continual problem getting into vehicles. As you have discovered, they eat the shite out of everything, and WILL eventually cause serious damage.
Worse, they breed like crazy, worse still they pee in their nests and will really cause your truck to stink. Finding a nest can be very problematic. I encourage you to find it. It likely has babies in it.
So far, you've been given good advice. I much prefer spring traps, as they are most effective. A glue trap can be drug off into places you really don't want them to be dieing. Do not use poison - they will indeed go to their nests to die - not good.
As to bait, I prefer peanut butter to bacon. Bacon can be gotten off the trap, whereas they will continue to lick at the PB.
For a car kept outside, you have got to stay preventive, and keep traps set beginning in the fall. Discovering them after the fact is bad.
@Carl_G I don't want to sound like an arse, but did you do these things I suggested? You have got to set traps, and monitor them, all winter.
And this: "Obviously a mouse nest. Can anyone tell me where the mouse would have obtained these types of fiber/threads from? The only one that looks familiar is from the yellow firewall insulation.
Maybe the insides of the seats? Under the carpet?
Respectfully, where the fibers are from is irrelevant. Once mice are around they can and will get anywhere in your vehicle, and they will chew everything - rubber, plastic, paper, wire insulation.
I'd highly recommend the PB-baited spring traps as before set INSIDE the cabin, say on the floor. Put them on a rag or something, as they often bleed when trapped.
Very surprised your cabin doesn't smell like pee.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
