View Single Post
Old 03-19-2013, 07:11 PM
blizz86's Avatar
blizz86 blizz86 is offline
Real Name: Brian - 20
blizz86 is on a distinguished road
blizz86's Avatar
Originally Posted by Ape-X View Post
Hey everyone,
Gonna bring this one back from the dead... I'm new to the forum, glad I found it. Our 2000 2wd SR5 is our work horse and DD. I'm having the same low idle as some of the members have stated here. Sometimes it starts up fine and idles normal... 700 or so... but sometimes it fires up and almost dies... falling to an idle of about 350. It will almost stall with the accessories pulling on it at very low speeds under no throttle, etc. power steering.
I've begun checking all of the vac hoses around the intake manifold. some are old and crusty, need replacing, though playing with tthem didn't seem to raise the idle at all. If I pull one, then engine will die in seconds.
cleaned the MAF....
gonna do the plugs tonight...
otherwise I've got nothing but question marks...
Vehicle drives seemingly normal.
Dave Funston
Hi dave, welcome to t4r.
So under some cold starts it sputters and takes giving the accelerator some go to get to normal idle right? Check out the IAC valve, there is usually carbon buildup. Clean that out and the throttle body with some carb cleaner
Propper Throttle body adjustment (INCLUDING IAC) WITH PICS!
2000 Limited 4x2 Build - OME lift // Tundra Brake Upgrade // Wet Okole // 265/70/16 Michelin X Radial LT2 // 3" FXR + 50 w Morimoto 5k // 1.25" Spidertraxx 4 corners
2012 SR5 4x4 [Magnetic Gray]: Stock suspension // OPOR TE sliders (trimmed rocker panels) // Husky Mudguards // CMG Roof Rack
blizz86 is offline   Reply With QuoteReply With Quote
