[QUOTE=burnera;1341231]
To do list so far, from most important to least:
Originally Posted by burnera
-Starter is on 'tap to start' status. (I just need to replace the solenoid right? or just replace the whole thing?)
I new one is not that much, and you can get one with a lifetime warranty.
-pulls left when braking (i dunno bout this one. Start by checking the pads and rotors i guess?)
You have a caliper that is not working. Replace both sides.
-transfer case (seller said sometimes it works, sometimes not. i'm guessing its a relay or the vacuum lines. )
Check the ADD vacuum lines in the front differential.
-leaky power steering pump.
10 to 1 says it has power steering fluid in it and not ATF. Change fluid out and I bet the leak goes away.
-bumpy. Hitting potholes delivers a great shudder to the truck, it feels just like axle hop from hard launches.
-needs shocks n springs. (i plan on using an OME kit)
Good call! Here is great kit that gives you some mild lift as well.
*NEW* Full OME Suspension '90-'95 4Runner - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
needs tires (first set will just be for road use, all seasons. I don't really plan to ever get huge tires, but will get some off road specific tires if i can find another set of rims)
Consider the BFG All terrain KO. They are a good tire both on and offroad.
-undo the horrid sound system wiring.
Car Toys.
