First, if you've never replaced the EFI relay, you might consider doing so. I would check the following:
1) check fuel pressures (rest and running).
2) o2 sensor, replace if the sensor has 90k or more
3) t-stat ( make sure it is not staying open, or partially)
4) replace fuel filter and plugs.
5) check for vac leaks around injectors and clogged pcv
6) clean out throttle body
regards
