Real Name: Kevin
Real Name: Kevin
If the brake pedal firms up with a couple pumps then goes soft again, it's a leak. If it's just plain soft, you probably have air in the lines and just need to bleed them again. Don't forget the LSPV.
Steering is easy - raise the front, move the wheel until the pitman arm is pointing straight back. If the steering wheel isn't centered at that point, take it off and center it. Now check the wheels, if they aren't pointing straight ahead, you can do a driveway alignment, or better yet take it in for a professional alignment. Squeaking is more likely to be a tie rod end than the steering box.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
