Rear hatch, upper left hand corner (driver side) is a 4"x 1 1/2" wiring cover you can pop out. you'll see the wires leading to the third brake light. tap into them there. Use scotch locks or solder them. your choice. Green-Yellow is the hot wire. White-Black is the ground side. PM me if you need to look at the wire diagram.
Take your time laying out the holes. This is the most important step. Once layed out, center punch the holes to prevent drill wander. Drill using slow speed. The install is not as bad as it seems.
Also, use some touch up paint to dress the holes. This is for corrosion prevention.
Good luck!
2006 4Runner SR5 V6. Galactic Gray Mica, Sunroof, Rear Spoiler, Cargo Net System, Valor Chrome Exhaust Tip, Toyota All Weather Mats, Custom Seat Covers, K&N, Fumoto Oil Drain Valve, Running Synthetics fluids throughout, 620/740 Hz Italian Air Horns, Hobbs Hour Meter, GM/Hobbs 25' Reel Type Underhood Trouble Light. Thought about de-badging it but she said NO!
