View Single Post
Old 08-28-2013, 09:06 PM
Flava Flav's Avatar
Flava Flav Flava Flav is offline
Flava Flav is on a distinguished road
Flava Flav's Avatar
'11 5th Gen 30K Svc - Do's/Don't
Ok, let me start saying that yes, I searched the Forum for about an HR for the answer b4 I posted this. I found nothing specific to the 5th Gen, hence the post.
Went to my local Stealership and got the print out for the 30K Service and this is what I was quoted for roughly $260 bucks. Obviously some of this is DIY but I'd like a 2nd/3rd/4th/Umpteenth opinion on the matter/service so I can save some $$$. I'm a baller on a budget.
Included Service - Per Stealer
BOLD TYPE = DIY
  • 00TS1M: ROTATE TIRES
  • 00TS1R: REPLACE ENGINE OIL & OIL FILTER
  • 00TS2R: REPLACE ENGINE AIR FILTER
  • 00TS3L: LUBERICATE PROPELLER SHAFT
  • 00TS3R: REPLACE CABIN AIR FILTER
  • 00TS6M: RE-TORQUE PROPELLER SHAFT BOLT
  • OOTS8M: RESET OIL REPLACEMENT REMINDER
  • 0TS4IN: INSPECT FUEL TANK CAP GASKET WTF DOES THIS MEANS???
  • 0TS5IN: INSPECT FUEL LINES & CONNECTIONS, FUEL TANK VAPOR VENT SYSTEM HOSES, FUEL TANK BAND
  • TS10IN: INSPECT BRAKE LININGS/DRUMS & BRAKE PADS/DISCS
  • TS11IN: INSPECT BRAKE LINES & HOESES
  • TS12: INSPECT BALL JOINTS & DUST COVERS
  • TS16IN: INSPECT EXHAUST PIPES & MOUNTINGS
  • TS19IN: INSPECT STERRING LINKAGE & BOOTS
  • TS22IN: INSPECT STEERING GEAR BOX
  • TS23IN: INSPECT AUTOMATIC TRANSMISSION FLUID
  • TS27IN: INSPECT REAR DIFF OIL
  • TS37IN: INSPECT ENGINE COOLANT
  • TS43IN: INSPECT RADIATOR & CONDENSER
  • TS44IN: CHECK DRVR FLOOR MAT
  • TS45IN: INSPECT/ADJUST ALL FLUID LEVELS
  • TS46IN: INSPECT THICKNESS MEASUREMENT & DISC RUNOUT
  • (DD) DBRAKE: CLEAN/ADJUST & LUBE THE FRONT & REAR BRAKS….SPLG?
  • (DD) DBUNDLE: BUNDLE DISCOUNT
If anyone can chime in on w/e I don't need, that'd be helpful. TIA guys!!!
Flava Flav is offline   Reply With QuoteReply With Quote
