Originally Posted by Jono.ful
The OP is running bilstein 5100's, not ome struts. At anything other than the lowest setting, that guide is going to be useless. I have struggled with enough alignment issues and the resulting tire wear/rubbing to know the value of aftermarket uca's. The consensus of the hoard is that uca's are required to maintain correct alignment angles after even a moderate lift. Chose to disregard that advice at your own peril.
I agree on the UCA's......ARB themselves wouldn't comment much on the caster settings and aftermarket UCA's. Here is from their 4Runner build and notice how they ignore the alignment post questions other then to post a out of speck one that the dealer did. Start at #184 .....
ARB 4Runner Build - Page 19 - Expedition Portal
