Real Name: Connor
Real Name: Connor
Just keep a chain or strap with to wrap around the axle and something solid on the frame to limit droop if doing any work with a hi lift on the rear. (Insert typical disclaimer about never just using the hi lift to support the truck while you work on it and use proper jack stands/support)
Short Bus v5.1
98 3rz/w59 Taco SAS on 37's with a 4.7 crawler
Sky's housing, Longs, PSC assist, dual locked, TG trunion bearing eliminators, lots of miles.
