View Single Post
Old 08-16-2014, 01:40 PM
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
What is the stock MAF tube diameter?
My '99 5vzfe has the type of MAF sensor that bolts into the pipe (instead of the housing and pipe being all one assembly like on the '96-'98 models).
What is the inside diameter of the MAF tube? I tried to measure it with my dial calipers, but at one end of the pipe, the opening is larger, and transitions to a slightly smaller diameter closer to the MAF. My dial calipers couldn't reach down the pipe far enough to measure the smaller diameter.
I'm thinking the diameter is anywhere between 2 5/8" and 2 7/8". Does anyone know exactly what it is?
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - uaEFI Standalone ECU - DW255 fuel pump - 550cc fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - 265/75/R16 Cooper Discoverer AT3 - OME 906 Rear Coils
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
