View Single Post
Old 08-18-2014, 06:06 AM
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
Originally Posted by TheDurk View Post
Also, that assembly includes TWO sensors: The MAF (two wires inside small tube) and the Intake AirTemp sensor (bulb on outside of tube). If you are trying to build your own MAF sensor assembly, I applaud your initiative but I think it is more effort than it is worth. Rockauto sells off-brand sensors for like $50. Has to be better than a homebuilt.
Lol, I'm not building my own sensor. Do people actually do that? And yeah, I know the IAT is integrated into the unit.
I'm going to give CX's turbo manifolds and downpipe a go, and I need to build my own intake from the turbo to the throttle body. I need to maintain the same MAF tube diameter so to not throw the ECU off. Build thread to come soon.
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - uaEFI Standalone ECU - DW255 fuel pump - 550cc fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - 265/75/R16 Cooper Discoverer AT3 - OME 906 Rear Coils
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
