View Single Post
Old 08-30-2014, 09:50 PM
gmv4k gmv4k is offline
gmv4k is on a distinguished road
Changed forward o2 sensor.
154040 miles
Current Avg MPG before new o2 sensor install: 17.4mpg
Part Number: Denso 234-4154 Oxygen Sensor(i think or Denso 234-4162, those are the 2 I bought for before and after cat)
Amazon.com: Denso 234-4154 Oxygen Sensor: Automotive
OEM nuts (part number 90179-08059) x 4
Been sitting on the forward o2 sensor for awhile and finally got around to trying it. I didn't have codes or anything, just working on maintenance stuff. I read removing the plug was going to be real pain but it was actually really easy. My o2 sensor was missing one nut. I broke the other nut/stud trying to remove it. Next time heat it up, I can't believe I forgot. But I used this
Irwin Industrial Tools 394001 Bolt-Grip Bolt Extractor Base Set, 5-Piece - Bolt Extractor Kit - Amazon.com
And it really gripped the old rusted nut... well too much, I think I used the 13mm one (doesn't come with the 12mm). It took the whole stud with it. I figured I was only running with 1 nut for awhile anyway. I'll see how this goes. If it leaks or I get codes I'll get it welded. I was thinking about putting steel worm-clamps on it too if it becomes an issue. And I anti-seized the crap out of the one nut on there.
This pic really helped to remove the plug
taken from 4x4Wire - Tech: Time to Replace the O2 Sensor on your 3rd Gen Toyota?
With a small screwdriver, seen in the next image, with my feet dangling out the passenger side, looking over the exhaust I used the small screwdriver to pry the latch up. Very easy. I used a flashlight to highlight the area. Didn't remove any bolts. Took 15 seconds once I saw the picture above.
old o2 sensor and small screwdriver to remove the plug.
So far so good. I probably should have disconnected the battery. But i think it's improving. Not as sluggish anymore. I'll update later with mpg and experience.
1998 4runner Ltd - 4x4 E-locker - TBU 199mm - B&M Tranny Cooler - Ultra-Guage - Rust Bucket
gmv4k is offline   Reply With QuoteReply With Quote
