These are the ones
legokcen
sells.
front D ring mounts
Trackdecal.com - Road Course Decals and Motorsports Graphics
Finally got around to installing these. Had them sitting for over a year. I was a little confused with the bolts. After you remove the passenger side you're left with 2 long bolts, I tried to re install my new mount but one of the bolts were too long. Then I did the driver side and one of the bolts was too short. Ah ha.
Threw some anti-seize on it and torqued it 83 ft/lbs. I couldn't find a torque spec for it so I just did what I would do for wheel lugs.
Removing these bolts were easy even on a NE vehicle.
Off with these.
From the front. I think I'm going to have a problem clearing the front fairing when a D shackle is under load.
I'll work on getting a shackle on there.
