Originally Posted by BlackWorksInc
I don't have the EWDs on me right now, but I would suspect that the shift position switches are similar or the same. The ECU knows what gear it's in based on switches installed on the transfer case. Thus lever or switch, the ECU verifies what position the transfer case is in before activating the ADD, if the ADD does not respond or the circuit is not hooked up; the transfer case should default to the open position in an attempt to save itself from possible damage. At least that is how most of our electronic transfer cases with these days.
Makes sense, but the issue im seeing is that in the J shift models with multi mode they have a switch/sensor on the shifter or transfer case I would assume that recognizes the different shift placement to engage the CDL. On the 01-02's its not automatic. I bring this up because I would think the OP's problem lies in that area of his wiring the ECU to the older style J shift switch/sensor for CDL.
