I like the mid-console custom cover, and the rust inhibitor treatment with the bed lining coating. Good luck with the seating, that is important, its where you sit! You might want to consider some memory foam padding in your seat refinishing, that gets a lot of use, the denser the foam, 5lb/5.5/6/6.5lb. the better and longer lasting. (afaik) Thanks for the parts! GREAT custom dash work below too!
Toyo's 4me!
