Originally Posted by 96r50
Looking good so far!
Do you have any more info about these?
The Scangauge II Bracket is from Paranoid Fabrications.
1st Gen Tacoma ashtray ScanGauge II holder | Catalog Products | Shop | Paranoid Fabrications
I bought the setup used from a forum member and honestly was just after the Scangauge II. But... When I received it, I noticed the bracket (painted black) would slide into the lower console perfectly and I added double sided tape to the top. Perfect fit. I angled the bracket and it sits perfectly. Drilled a hole in the back of the console, with a gasket, and everything seems to work perfectly.
The USB in the glovebox:
Got a right angle USB plug, drilled into console with a gasket. In my FJ, I actually spliced the USB Port and Aux Port from behind and ran to head unit and glovebox. I will end up doing this as well, as I hate the sight of cabling.
In glovebox, pried out the round plug port, (Not a good job, need to touch up the scratches). Mounted a USB extension with the round mounting plate, found on Amazon, and used a gasket to keep it snug:
The Fire Extinguisher and bracket are basically any one you can pick up on Amazon. The bracket is just mounted to the side compartment door:
The Flashlight is mounted using Quickfists:
Amazon has some great package prices.
