Real Name: Mason
Real Name: Mason
Originally Posted by Kryptoroxx
I couldn't tell you in good faith to add any more to the weight that swing out carries without first plating the frame and using a bigger hinge.
Remember that stuff weighs a good amount and fuel or water sloshes around. I could see adding a shovel, pick ax, and high lift but I wouldn't go adding jerry can holders personally.
Also you've got a fairly good sized storage space where your tire used to be. You could rig something up to use that space too.
Thanks for the input. Honestly not sure how much weight the swingout could handle. I can tell you it seems very solid in person. The bolt is a double sheer with 1" tapered roller bearing. The original owner told me his intent was to add the jerry cans. That is a good tip though about the unused space below where the tire would be. Not sure how safe it is to put gas cans below though (Not that they are real safe hanging out on the rear of the 4R).
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
