Originally Posted by GreenbowCounty
For clarification, it does not drop in properly between the wheel wells (first pic) without modification correct? Looks good by the way man.
It is a very tight fit. I didn't bolt it down to try it but it will rub the carpet quite a bit.
Originally Posted by zhhfrcd
Dude, nice start! If you ever get around to it, I feel like there'd be more than just me who'd be interested in a write-up on how you wired those footwell lights -- did you tap into the little rubber button in the driver door frame?
Provide 12v to the positive side of the lights and then connect the ground side to the door jam switch. When the door opens the circuit is complete.
1999 4Runner Limited 4WD Locker
2006 Lexus GX470
2013 Toyota Tundra TSS 4WD
