View Single Post
Old 05-03-2015, 10:01 AM
cbielat's Avatar
cbielat cbielat is offline
Real Name: Chris
cbielat has a spectacular aura about cbielat has a spectacular aura about
cbielat's Avatar
Real Name: Chris
cbielat's 2011 SR5 Build Thread
COUPON CODE: CBIELAT
RECEIVE 5% OFF BLACK OAK LED LIGHT ORDER
USE COUPON CODE CBIELAT AT TIME OF CHECKOUT
BlackOakLED Lights - LED Light Bars, Mounts & Accessories – BLACK OAK LED
Instagram: cbielat
I'm computer illiterate so I copy and pasted my Excel sheet. Doesn't exactly match up well but you get the idea.
4Runner Build Revamp Spread Sheet
Other Manufacturer Name/Size/Dimensions Part Number Price Website Status Notes
FRONT SUSPENSION
Shocks Radflo 2.0" shock body/600# spring $853.00 Overland Warehouse (no longer) Removed Sold
Upper Control Arms SPC Light Racing $528.00 Overland Warehouse (no longer) Removed
CURRENT SET UP
Long Travel
Total Chaos 2" Long Travel Suspension Kit Race Series $3,500.00 offroadwarehouse.com Installed
Axle Shafts Total Chaos 2" $603.98 offroadwarehouse.com Removed
Total Chaos 2" Spare $306.00 Total Chaos Installed
Removal Pipe 16" X 1 1/4 CV Shaft Removal Tool $7.00 Home Depot Installed
Axles RCV Performance Long Travel Spec $3,000.00 rcvperformance.com Installed
Shocks
King 2.5" w/ Remove Reservoir $1,600.00 Installed
Upper Control Arms Total Chaos Included In Long Travel Kit
Lower Control Arms Total Chaos Included In Long Travel Kit
Spindle Gussets Total Chaos Weld On Spindle Gussets $60.00 chaosfab.com Installed
Cam Gussets Total Chaos Weld On Cam Tab Gussets $89.00 offroadwarehouse.com Installed
REAR SUSPENSION
First Set Up Radflo 2.0" bodies $456.00 Overland Warehouse (no Longer) Removed
Eibach 2" Lift Springs $220.00 Overland Warehouse (no longer) Removed
Daystar Rear Coil Spring Spacer $20.00 T4R.Org Member Removed
CURRENT SET UP
Long Travel
Shocks Radflo 2.5" bodies -28" extended $630.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Springs Metal Tech Dual Rate 3" Lift Springs - Heavy $230.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Bump Stops Metal Tech Extended $69.95 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Upper Links Metal Tech $250.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Lower Links Metal Tech Offset $325.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Brake Lines Metal Tech Extended $60.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Sway Bar Custom Double Disconnect $125.00 T4R.Org Forum Member Installed
Track Bar Rokmen Adjustable Track Bar $400.00 rokmenoffroad.com Installed
TIRES Good Year 285/70/17 Duratrac $1,400.00 Sears Store Installed Set 1
Good Year 285/70/17 Duratrac $1,400.00 Good Year Store Installed Set 2
Mickey Thompson 315/70/17 - 34.6" (35") Baja MTZ P3 $1,250.00 ATD Tire Distributors Installed Sponsorship Pricing
37/12.50/17 Used $60.00 Facebook Market Place Installed
Maxxis 37/12.50/17 Razr $1,300.00 www.simpletire.com Installed
WHEELS FN Wheels Countersteer Type X - 17" $900.00 http://www.fnwheels.com Installed Matte Black
Toyota Toyota Second Spare Wheel $100.00 Toyota Installed
Battle Born Wheels Bootlegger 17/9.5/17 Beadlocks $1,500.00 www.battlebornwheels.com Installed
FN Wheels Countersteer Type X - 17" Second Set $400.00 fnwheels.com Installed Gunmetal Grey - Sponsorship Pricing
BRAKES EBC Ultra Slotted Rotors $360.00 buybrakes.com Installed
EBC Green Stuff Pads $360.00 buybrakes.com Installed
Power Stop Brake Kit Second Kit $380.00 rockauto.com Installed
LOCKERS ARB Air Locker (T4R Group Buy) RD193 (Rear Only) $1,021.16 T4R.Org (Group Buy) ECGS Installed
Air Locker Front $1,040.86 eastcoastgearsupply.com
AIR ARB Onboard Compressor CKMA12 $275.24 T4R.Org (Group Buy) ECGS Installed
Viair Portable Compressor 450P $299.00 amazon.com Installed
LOCKER AIR LINES Rocky Road Front Locker 7' Stainless steel http://www.rocky-road.com/toyota-arb.html
Rocky Road Rear Locker 13' http://www.rocky-road.com/toyota-arb.html
GEARS Rear Diff Nitro four.fiftysix $299.99 T4R.Org (Group Buy) ECGS Installed
Front Front Diff Nitro four.fiftysix $285.00 T4R.Org (Group Buy) ECGS Installed
Front Diff (Driver Side) ECGS CV Input Spacer 8" Clamshell $45.00 eastcoastgearsupply.com Installed
ECGS Spacer Tool $60 eastcoastgearsupply.com
Rear Diff ECGS Master Rebuild Kit 8.2" $290.00 eastcoastgearsupply.com Installed
Front Diff ECGS Master Rebuild Kit 8" Clamshell $300 eastcoastgearsupply.com Instaled
SKIDS RCI Front Engine $220.00 http://www.rcimetalworks.com Installed
RCI Transmission $165.00 http://www.rcimetalworks.com Installed
RCI Transfer Case $220.00 http://www.rcimetalworks.com Installed
RCI 2nd Transfer Case Skid $270.00 www.rcimetaworks.com Instaed Set 2
RCI Gas Tank Skid - Aluminum $350.00 www.rcimetalworks.com Installed
Custom UHMW Sheet $201.56 www.piedmontplastics.com Instaled 1/2" thick
UHMW parts $100.00 Fastenal Instaled Bolts/bits
Toyota-Trail Edition Gas Tank No Charge Installed
Rear lower link
Rear Shocks FJTOYMAN Rear Shocks $150.00 Installed
RCI Rear Differential $250.00 rcimetalworks.com Removed Sold
Front Lower Control Arm
SLIDERS OPOR/Metal Tech $650.00 metaltech4x4.com Removed
Custom Built Myself Sliders $200.00 Grant Steele Installed $100 Steele cost / $100 Grinding/Cutting discs
BUMPER Front CBI Steel $1,700 cbioffroadfab.com Installed
Rear CBI Steel $1,400.00 http://cbioffroadfab.com Installed
CB RADIO Cobra 75 WS XT $100 amazon.com Installed
Antenna Fire Stick 3' Whip $25 amazon.com Installed
Mount Diamond K400 $40.00 amazon.com Installed
Handheld Baofeng Handheld $30.00 amazon.com Installed
FENDERS Front Fenders $88.00 http://www.partstrain.com
LIGHTING Rear Bumper Extreme LED Solutions 2x2 Pod LED (2) Installed
Front Bumper Black Oak LED 2x2 Pod 10W Cree (2) $159.94 blackoakled.com Installed
Black Oak LED 2x2 Amber Pod Covers (2) $17.94 blackoakled.com Installed
Ditch Light Brackets CBI Ditch Light Brackets $55.00 cbioffroadfab.com Installed
Black Oak LED 2x2 Pod 10W Cree (2) $156.00 blackoakled.com Installed Sponsorship Pricing
WINCH Superwinch Talon 12.5 SR $900 Superwinch.com
Superwinch Solenoid Relocation Kit $100 Superwinch.com
RECOVERY
Winch Shacke Mount Winch Line Factor 55 Flatlink E $145.00 Southeast Overland
Tire Deflation ARB 505 EZ Deflator $42.00 amazon.com Installed
Snatch Strap Warn Recovery Strap $90.00 amazon.com Installed
Tire Repair Kit ARB $42.00 amazon.com Installed
D Ring Shackles N/A $20.00 Installed Stolen
Hitch Insert N/A $25.00 Installed
MISCELLANEOUS
Paint Protection 3M Front Bumper/Head Lights/Grill $350 http://www.invisiblemask.com Installed
Breather Custom Rear Diff Breather Mod $20.00 Installed
Antenna Custom Stock Antenna Block Off $5.00 Installed
Plastidip Custom Plastidip Chrome Accents $30.00 Installed
Paint Custom Spray Paint Sliders/Skids $40.00 Installed
Powertank Powertank Powertank (Air) $550.00 Installed Won in Raffle @FJ Northeasters Run
Fire Extinguisher $40.00 Installed
Roof Basket Rola Roof Basket $171.00 Amazon.com
Hi-Lift Jack Hi-Lift Jack $112.00 Amazon.com
Compressor Mount Mount Compressor Mount $86.00 Leroy from FJNE(Bandiworld)
Ladder Gobi Ladder $120.00 Private Seller
Soft Shackles Soft Shackles Southeast Overland $60.00 Installed
LCA Cam Bolts/Sleeves Toyota Cam Bolts/Sleeves $127.00 Toyota Installed
Tie Rod Ends
Outer Tie Rod Ends Toyota $93.00 Cost +10% Installed Set Three
Inner Tie Rods Toyota Installed Set Two
CV Axles Toyota CV Axles for TC Replacement Shafts Qty. 2 $640.00 Installed
Transfer Case Toyota Transfer Case Switch $56.00 Installed
Wheel Bearings & Hubs Toyota Wheel Bearings & Hubs $700.00 Toyota Installed Set One
Wheel Bearings & Hubs $220.00 rockauto.com Installed Set Three
Steering Rack Toyota $720.00 Cost +10% Installed Set Two
Bushings Lower Control Arms Total Chaos Total Chaos LC Bushings $115.54 chaosfab.com Installed Set Three
Uniballs Lower Control Arms Total Chaos Total Chaos LC Uniballs $180.00 chaosfab.com Installed Set Two
Body Lift Leroy Horwedel Bandiworld 1" Body Lift $75.00 Private Seller Installed
Skid Front Engine Skid Front Skid Bolt Spacers $2.50 homedepot.com Installed Set Two
Rod Ends Metal Tech LT End Links Currie Enterprises Johnny Joints $232.81 currieenterprise.com Installed Set Two (4)
Bushings Metal Tech LT End Links Metal Tech Bushings $39.00 metaltech4x4.com Installed Set Two
Bushings Steering Rack Bushings Whiteline Poly Bushings $53.00 energysuspension.com Installed
Bushings Rear Shock Pin Mount Radflo Rear Shock Pin Mount Bushings $43.00 radflo.com Installed First Replacement Set
Tail Light Driver Side Rear Tail Light Toyota Driver Side Rear Tail Light $137.00 Toyota Installed On Second Replacement
Storage Box Custom Myself Rear Storage Box $250.00 Home Depot Installed
LABOR
Gears/Locker ECGS/ARB $1,600.00 T Jays Transmission Installed
Long Travel Kit Total Chaos $1,520.00 RMS Off Road Installed
Cam Gussets Total Chaos $395.00 Eastern Welding Installed
Blown Needle Bearing Front Diff ECGS Bushing Replacement Front Diff $60.00 BDR Automotive Installed Set Two- Tjays Transmission never installed the part to begin with.
Steering Rack Replaced Steering Rack $1,200.00 BDR Automotive Installed
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
cbielat is offline   Reply With QuoteReply With Quote
