View Single Post
Old 06-11-2015, 11:45 AM
SnowLizard's Avatar
SnowLizard SnowLizard is offline
SnowLizard is on a distinguished road
SnowLizard's Avatar
SnowLizards Build thread
Current Mod thread... this will be edited with mods and things as I change it (and update the post)
current Mileage 180,XXX = 2/16/18
20160116_140134
As I Bought Brand New to me
OD : 152,575
One Owner
sitting next to my 97 4runner
20150611_075654
3.4 v6
4x4 with limited multi-mode
Tan Leather interior
Rear Dif Lock
limited 5 star wheels
265/70r16
Running Boards
Tow Hitch
Roof Rack
Stock front/rear bumpers
fog lights
Current Build: - March 2020
Front End
-Open: 4.30 gear Ratio
-spidertrax 1.25 spacers
-Tundra Brakes 231mm
-OEM ITR - 162k
-L/UBJ OEM - 162k
-5100 bilstein tundra shocks
-stock 99 tall springs
-steering/sway bar bushings - 162k
-1" Differential Drop
- fenders trimmed, flares 'hollowed' to fit 33's
- OEM new steering rack
Rear End
-E-locker: 4.30 gear Ratio
-OME 906 rear coils
Stereo: (It works, when it doesn't I'll upgrade)
-kenwood
-6inch front doors
-6x9 rear doors
I don't have refined taste on music/sound... it just has to work.
Undercarriage / Drive Train Upgrades
-Removed Running boards
Interior Upgrades
-Scangauge II
-Weathertech Digital-Fit Floor liners front
Engine & Performance Upgrade/Maint
-ISR (Intake Silencer Removal)
-OEM filter
-KOYO Radiator
-B&M trans cooler (rad insync) -165k
-water pump -162k
Armor
Stock Skids/front&gas
-Savage Rear Bumper 2016
Exterior
- Altezza Tail Lights: black+clear
- tint match front windows
- tint banner on windshield
- tint all 'colored' glass for less heat (THIS IS AMAZING!)
Wheels/Tires
-99 Limited star stock
-285/75/16 BFG AT
Maintenance
Date Miles Description
06/10/15 152,572 tow truck from Cali to AZ
06/12/15 ---null-- temp tag
06/12/15 152,600 emissions
06/13/15 ---null-- registration and state tax
06/13/15 152,612 DTS - trans flush, eng oil change, pwr steer flush
07/01/15 ---null-- scratch and dent spacers
07/21/15 154,038 DTS - RR driver rear axle bearing and seal
07/25/15 ---null-- dealer - spark plugs and wires, fuel filter, PCV valve
08/06/15 ---null-- scan guage
10/03/15 155,000 tundra brake upgrade
10/27/15 ---null-- brake lines
10/27/15 157,700 RR front and rear CAT's
10/28/15 157,700 axle, t-case, engine oils + eng filter
10/28/15 ---null-- brake fluid
12/31/15 ---null-- savage off road bumper
03/01/16 ---null-- timing belt, rad hose's, t-stat, door switch
03/02/16 ---null-- timing belt tensioner
03/08/16 ---null-- radiator cap
03/16/16 ---null-- OME-906 rear coils
04/06/16 ---null-- J-Pipe Muffler Mod (NO MORE DRONE!)
04/19/16 162,014 dealer - syn oil change
04/23/16 ---null-- dealer - ball joint bolts, air filter
05/02/16 ---null-- dealer - ball joints, water pump, fan shroud
05/02/16 162,400 4 shocks, fan clutch, rear bumper and springs install
05/03/16 162,400 Lifetime Alignment purchase
06/01/16 164,521 DTS - install SS brake hoses
06/03/16 ---null-- front diff drop
06/11/16 ---null-- tow wireing harness
06/25/16 165,400 install trans cooler, tied with stock cooler
06/25/16 ---null-- DTS - trans leak, hose replace
07/05/16 165,465 dealer - syn oil change
08/19/16 ---null-- DT - Nitto Trail Grapplers 285/70r16
08/24/16 168,746 DT - Nitto Trail Grapplers 285/70r16
11/02/16 171,002 dealer - syn oil change
12/28/16 ---null-- 3wire mods
01/06/17 ---null-- dealer - gaskets, intake hose, spark plg gaskets
01/18/17 ---null-- dealer - DS door gasket
01/20/17 ---null-- Kenwood wire adaptor and pioneer door speakers
02/03/17 ---null-- battery core return
05/31/17 ---null-- dealer - steering rack (self install)
06/03/17 ---null-- front drive shaft replacement
06/05/17 175,895 brake fluid flush, free lifetime alignment
07/28/17 176,949 dealer - air filter and syn oil change
08/11/17 177,000 emissions
10/16/17 ---null-- battery
10/24/17 ---null-- battery core return
11/20/17 ---null-- tools rental, light bulb
11/24/17 178,765 check wheel alignment
11/24/17 ---null-- return tool rental
11/24/17 ---null-- blinker fluid
11/24/17 ---null-- misc tool, cotter pins
11/25/17 178,768 free lifetime alignment
12/09/17 179,111 dealer - air filter and syn oil change
06/11/18 182,812 DTS - Trans Flush and Brake Booster RR
10/05/18 ---null-- 3 wire mod parts
02/15/19 188,437 DTS - oil change, wheel alignment, fan belts RR
02/26/19 ---null-- dealer - lower control arms
03/06/19 ---null-- syn oil
08/07/19 192,033 emissions
09/20/19 ---null-- DT - Used Tire for spare
11/05/19 ---null-- free battery exchange
11/15/19 192,760 RR t-case front output seal, overall check
12/21/19 ---null-- sway bar links, hatch struts
1999 3rd gen Ltd 4wd 3.4 auto dif lock - Build Thread SOLD!
2019 Tundra Sr5 CrewMax - 1 owner
Doubt kills more dreams than failure ever will.
SnowLizard is offline   Reply With QuoteReply With Quote
