Thread: Power Locks?
View Single Post
Old 11-13-2015, 01:23 AM
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Originally Posted by Smackhq View Post
So I'll admit that I had already pulled the relay block before I say your post so I'm probably just going to try and replace it.
Do you know which models are compatible with my part?
Do I need the exact year / model / part number?
These are the codes on the outside of the case.
0K15-1327
9060
A yard I get parts from has one from a 2000 Limited but numbers dont match.
0A10-1582
4910
Can you shed any light or suggestions on replacing it?
Thx again.
No I don't know what the numbers mean. I do know that if your vehicle has ignition disable and the donor vehicle doesn't, it won't work. There are other issues but I'm not up to speed on all of them. If it's free, you can always try it! Also, I believe the relay INSIDE the Body ECU is what actually fails, and you could maybe swap it out, but it is soldered in place. It's been done, if you search this forum you could probably find the link.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
