Originally Posted by Tek23
I've read/heard both sides of the story regarding the wheels being on the ground. I'm hoping to swing by my buddy's shop and throw it on a lift. Maybe we might be able to diagnose further while he's underneath and I'm driving.
One thing I didn't think of before, but I wonder if you put some grease into each of the rear u-joints, one at a time and then drive it to see if the noise reduces a bit. Greasing them one at a time and then driving would isolate which u-joint it may be. My thought is if the u-joint is bad but doesn't have a lot of play yet, maybe a shot of grease will quiet it down a little letting you know it is an issue. It would be pretty quick for you to do.
Running it on the lift while someone listens from below sounds like a good idea. If there was a way you could mount a GoPro under the truck while driving and putting it in different positions, one near the u-joint near the transmission and one near the u-joint at the rear differential, you could get some footage and hear the amount of noise coming from those different camera locations. If you have a GoPro, they do make different adhesive mounts that might work.
I had a u-joint go bad on a 68 Ford Bronco way back in the day. It was making a lot of racket and I had no clue what it was. At the time, I was working at a Chevron gas station and one of the senior mechanics listened to my truck while driving and immediately knew it was a bad u-joint.
Hope you get it figured out.
