Originally Posted by 08runnertjb
Appreciate the candid feedback. Interested in function as much or more than form, so if it doesn't work easily in actual application I may pass on it. It doesn't sound like the SSS hybrid would be any better. Seems the same issues would come into play.
I may have to consider a full bumper after all...
Thanks.
My picture above is using a SSS bumper. You are looking at the winch motor in the picture. The spool with line is on the right of the motor. Easily visible through the lower grill opening on the 14. My clutch has a T handle about 3" across. Straight pull up and rotate 90 degrees to free spool. I do have to open the hood for the wired remote, but if I'm stuck or helping someone else that's a minor concern. I can lower the hood to it's first latch if I need to. Most newer winches have the clutch assembly made so it can be "clocked" around its axis for ease of access. I can try to get you a better picture but it may take a couple days. I don't get home until after dark most days now.
