Originally Posted by pauldub
Nobody uses the gear oil weight recommended by Toyota??
I did, sort of. Don't know if all the years are the same but my owner's manual called for 80W-90. There's can't be that much of a difference between 80W-90 and 75W-90 so I understand why some are just using 75W-90 in everything since the transfer case and front diff call for 75W-90.
My manual actually said to use straight 90W for temps above 0 degrees F and use 80W-90 for temps below 0 degrees F. I couldn't find straight 90W, so I just got some 80W-90 and called it good.
