View Single Post
Old 07-15-2016, 02:45 PM
Konkordmusk Konkordmusk is offline
Konkordmusk is on a distinguished road
Originally Posted by TorqueOfTheDevil View Post
Errrrr, what?
I'd consider the crown wheel, pinion and bearings wearable items, they even have a run in period!
My only thought was that you meant the tube part itself, but that shares oil with the above mentioned, so regarding oil colour is irrelevant!
Eaton Recommend Mineral oil for use with Truetrac diffs... Toyota recommend Semi synth from memory. I can't remember what the Yukon recommendation was.
Certainly those items will wear...in the same way that seats wear, or steering wheel would wear; not necessarily an item designed to wear. The r+p certainly aren't items that one would change at regular intervals like brake pads. That is what I meant by wear item, apologies for lack of clarification.
The 4Runner does not actually drive. It simply rotates the Earth to your desired position.
Konkordmusk is offline   Reply With QuoteReply With Quote
