Originally Posted by Mark_BC
Are the gear ratios the same? Otherwise your front wheels will turn at a different speed. Search the forum on how to check ratios, basically jack up one wheel, spin it 20 times and get another person to count how many times the drive shaft goes around. Divide by 10. It will probably be 4.1
yeah thats why I have to put my ring and pinion in the 09 carrier, because the carrier i acquired is a 3.73 ratio. The more I think about a 4th gen housing swap, the more I want to make it happen, going to make some measurements over the next couple days, will post findings. I'm fortunate enough to have all the service data for Toyota's that a normal person could ask for, but haven't yet found exact measurements between axle housings.
