View Single Post
Old 08-29-2007, 08:35 AM
Rock Slide's Avatar
Rock Slide Rock Slide is offline
Rock Slide is on a distinguished road
Rock Slide's Avatar
Originally posted by lee
i have experienced exactly what rockslide says. i installed a switch to shut vsc & trac off and i actually usually run with it off (and abs off as a result) because i hate vsc's intrusive nature so much.
i have noticed it a lot more in 4hi, and i cant figure out why they would allow it to work that way
terrible system in my opinion.
Lee, thanks for chiming in. I knew you wheeled the heck out of your vsc/trac equipped 4Runner (more than most) and figured you had experienced this same issue.
Burton6509, I hope this helps you at least feel better knowing that nothing is wrong with your 4Runner. Unfortunately, Lee's right, it's a terrible system. I don't fully understand why Toyota would create it to work this way either. Seems to be very overly senitive.
Install the switch to toggle vsc/trac on or off (which also disables abs by the way), and you'll be set!
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
Rock Slide is offline   Reply With QuoteReply With Quote
