Valve Cover Leak
Based on what I've seen it looks like my valve cover is leaking a bit (175k, so no big surprise, I guess). I did notice what looks to be leaking at the PCV(?) valve also. Does this suggest that there's blow-by from a cylinder or two causing pressure and leaking? Or maybe a PCV valve problem is part of the cause...
One picture is the PCV, the other is the spark plugs with 55k on them (probably should have done sooner).
Stepsons 2000 4Runner Limited. E-Locker..Tundra 199mm Brakes. Blue Wire Mod. 3" OME 891 rear & Tundra TRD front. Duratrack MT 265/75 R16. TRD Trans Cooler. DRL Disable. Legal Limit Tint.
2004 Tacoma 4WD (Sold). / 2004 LR Discovery. 3" OME. (Sold) / 1982 CJ7. 4.0 MPI. (Sold) / 1989 YJ (Sold) / 1985 4WD Toyota Pick-Up (Long Gone!) 🤫 back to the dark side Land Rover LR4 for me..
