Thread: Oil Pressure
View Single Post
Old 01-27-2017, 08:38 PM
dsfra's Avatar
dsfra dsfra is offline
dsfra is on a distinguished road
dsfra's Avatar
Originally Posted by (none) View Post
This entire thread makes no sense. First you start off talking about oil pressure. Then you talk about removing the oil pressure switch and coolant flowing out. Then you say you are looking for oil temp.
If you want oil temp? They make drain plugs with sensors to replace the drain plug in your pan. That's by far the easiest way to get a good reading. I'd also bet that toyota probably already tracks engine oil temp somewhere (usually there is a sensor by the oil filter/cooler area.
If you are looking for oil pressure, go find that switch for the idiot light and add a tee like you mentioned. I encourage you to do it and post some results, i'd much rather have the gauges than lights.
Yeah - brain fade - sorry for the (my) confusion - meant to talk about "oil", not "coolant", flowing out. Damn keyboard - I typed "oil" but it came out "coolant". Thanks for being my proof-reader.
Two separate topics, ergo two separate paragraphs in the original post: First pressure, Second temperature. As far as I can tell, Toyota doesn't make oil pressure or temperature available on the bus - if they did I would be looking at the values on my ScanGauge, and avoid this whole thing. Might look around for the drain plug / temperature sender combo. Anybody happen to know where they're available?
2012 Silver Trail Edition, KDSS, Nav, 265/70-17 BFG A/T KO's, ScanGauge, B&M 70264 Tranny Cooler, 20" Opt7 LED Light Bar, LED DRL's, Prodigy P2 Brake Controller, Wired for Dual Wide-Angle Cameras on Rear of Trailer, Hitch and Rear Bumper Trailer Lights on Center Pin of Connector, Timbren Rear Bump/Springs, 19' Escape Trailer Thumping Happily Behind
dsfra is offline   Reply With QuoteReply With Quote
