Originally Posted by gfluff
5100s in the front with Tacoma springs are pretty good. Check your local Craigslist, I got mine for $40. 5100s on top setting plus the taco springs got me closer to 3 inches of lift.
In the rear, I now have Wheelers T12 springs. Slightly stiffer, closer to 2 inches of lift. I had 1.5 spacers before.
Your results may vary....
What are your needs, what are your plans for the truck? Towing? Heavy loads? Trying to fit a certain tire size?
Did you keep your shocks stock in the rear then?
As for my plans, It is my daily driver but I also plan on doing some light trails and beach driving. I wont be doing any towing, but I would like to add a rooftop tent eventually so I am assuming the added weight of that will become a concern.
I would like to upgrade to a 265/70/17 tire size, not sure if I can do a little larger size without rubbing becoming an issue.
