Originally Posted by TampaBay_4Runner
Agreed about the Moog springs. I was looking for a low cost but effective lift.
I'm happy to provide feedback once this setup is installed and some pics too. I'm not upgrading the tires right away since I just recently purchased the truck and it had brand new tires on it. Can't justify the added expense at the moment so it might look a little odd being lifted with small tires.
This is the truck I used as inspiration as far as lift is concerned. Should give you a good idea of what it will look like. MRpink's Build Thread
I like that a lot. To me that looks like the perfect amount of lift. You are going to have a great looking rig. I don't even think it looked odd with stock size tires. Are you doing the work yourself? I am apartment bound at the moment so I have no space for big projects like that. Plus, I do not have the confidence to take on a task like that yet, I draw the line at changing the oil and brake pads. I am new to the game so to speak.
Because I am going to have to factor in labor costs I am going to most likely put the suspension together piecemeal. I'm going to have install the bilsteins installed with the stock springs to level the truck out at first, then proceed from there.
