View Single Post
Old 08-13-2017, 06:09 PM
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Relentless Fabrication - In-house Only -
RPM Fab - $1050-$2250 -
4x4 Labs - $795-$2500 - Chopped Bumper Crossmember Necessary - DIY Kit Option -
Custom Swing-out
Some members, myself included, have added a swing-out to their stock rear bumper which requires trimming mounting location openings in the stock plastic bumper cover.
My rear swing-out
@Porqupine82's rear swing-out
Skid Plates:
You know the drill. Steel if you use them lots, aluminum if you don't rely on them. I would recommend getting a lower link skid if you like wheeling on rocks, that is one point that seems to get held up the most along with the gas tank.
ARB - 3mm Steel (Just under 1/8") - Front -
Bay Area Metal Fabrication - 3/16" Steel - LCA -
Budbuilt - 3/16" Steel/ Stainless Steel - Front, Mid, T-Case, Gas, Diff -
CBI Offroad - 3/16" Steel - Front, Mid, T-Case -
Icon Vehicle Dynamics - 3/16" Steel - LCA -
LFD Offroad - 3/16" Steel - Front -
OPOR - 3/16" Steel - Lower Link Skid -
RCI - 3/16" Steel/ Aluminum - Front, Mid, T-Case, Gas, LCA, Diff, Lower Link Skid, Bumper Filler -
Richochet - 1/4" Aluminum - Front, LCA -
Rocksteady Motorsports - 1/4" Aluminum - Front, Mid, T-Case, LCA, Lower Link Skid, Bumper Filler -
Shrockworks - 3/16" Steel - Front, Mid, T-Case, Gas -
Total Chaos - LCA, Lower Link Skid -
Sliders:
  • Replaces stock running boards in favor of a beefy steel tube that either bolts to the frame or is welded directly to the frame.
  • Can help protect your body from rocks, trees, stumps, and the occasional door ding from an adjacent car in the mall parking lot.
  • Some manufacturers include an option for a 'kick-out' which can help distance your body from an obstacle when the slider is rubbing against it.
  • Tube Construction:
    • HREW Tubing (Hot Rolled Electric Welded): Mild steel with a yield strength of around 40ksi. Will hold up to moderate use but will dent with heavy abuse.
    • DOM Tubing (Drawn Over Mandrel): Starts out like HREW but gets cold drawn over a mandrel which produces a more consistent and stronger tube. Yield strength is around 70ksi which means it is stronger and a better option if you frequent boulder fields.
    Youtube video showing the difference between tubing construction.
  • Bolt-on vs Weld-on:
    • I've never heard of anyone shearing a bolt on bolt-on sliders so as far as strength goes they are both equally sufficient.
    • Bolt on sliders can be removed and easily repainted once you get rock chips or boulder scrapes on them but they occasionally have fitment/compatibility issues until the manufacturer works out all the 'kinks'.
    • Weld on sliders can be welded wherever you want, which is great for guys with body lifts. But to touch them up with paint on your truck requires a bit of creativity.
4x Innovations - $204-$293 - Weld On - DOM or HREW -
Addicted Offroad - $350 - Weld On - Unlisted Matl. -
Bay Area Metal Fabrication - $325-$795 - Weld On - DOM or HREW -
Budbuilt - $525-$1040 - Bolt On - DOM or HREW -
C4 Fabrication - $525-$685 - Bolt On - DOM or HREW -
CBI Offroad - $500-$725 - Weld On - DOM or HREW -
Demello Offroad - $650-$1150 - Both - DOM -
Mobtown Offroad - $350-$700 - Weld On - DOM -
Northwest Trail Innovations - $250-$360 - Weld On - Unlisted Matl. -
RCI - $495-$745 - Bolt On - Unlisted Matl. -
Rago Fabrication - $800-$1000 - Bolt On - DOM -
Relentless Fabrication - $309-$470 - Weld On - DOM -
RPM Fab - $474 - Weld On - DOM -
Shrockworks - $454-$608 - Bolt On - Unlisted Matl. -
Stubbs Welding - $325-$650 - Weld On - DOM or CREW or HREW -
White Knuckle - $480-$830 - Bolt On - DOM or HREW -
Roof Racks: (Armor For Your Roof?)
  • Allows for the storage or mounting of awnings, flat totes, Rotopax, recovery devices, chickens, light bars, shovels, kayaks, tents, fishing poles, firewood, etc...
ARB - $920-$1300 -
Baja - $860-$900 -
Ecotechne - $750? -
Eezi-Awn K9 - $1050-$1325 -
Frontrunner - $1045 -
Gamiviti - $830-$1460 -
Gobi - $1600 -
Prinsu Design Studio/ CBI - $695-$815 -
Sleekster - $450 -
Sherpa Equipment Co. - $800-$1000 -
2005 4R "The last of the V8s!" - TC +2 LT. - Lockers Front & Rear - 37's - Dana 60 - Build Thread
2005 Tundra 2WD Regular Cab 4.7L - Chopped Frame - Short Bed Swap - Lowered
2019 Tundra 4WD Double Cab 5.7L My Website: Full Metal Designs
Inv4drZm is offline   Reply With QuoteReply With Quote
