View Single Post
Old 09-09-2017, 08:42 PM
Dirtco's Avatar
Dirtco Dirtco is offline
Real Name: Jeremiah
Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all
Dirtco's Avatar
Real Name: Jeremiah
Dirtco's Adventure Thread
1999 Limited 4Runner – Autumn Blaze Metallic
fullsizeoutput_42f
Modifications…
Suspension:
Front:Custom solid axle swap
TG Rock Assault driver drop Tacoma width housing
Fox 14” 2.0 DSC coilover shocks, 125/250 Eibach springs
TG Links and Creeper joints
Barnes4x4 Panhard brackets and shock towers
Rear: OME 850 Coil Springs
Toyota "Tokico" black 80-Series Land Cruiser shocks
Rear lower shock mounts relocated higher
Rokmen HD Adjustable lower control arms
ToyTec HD Adjustable pan hard bar w/ adjustable bracket
Gusseted upper stock panhard bracket
ToyTec HD Adjustable upper control arms
Custom limit straps (Poly performance)
Rear sway bar removed
Extended progressive rate rear bumpstops
Wheels and Tires:
Trailready 17x9 HD Beadlocks (3.5” backspace) w/ Mini Monster Valves
Cooper STT Pro, 37x13.50x17
Drivetrain:
Front: High pinion 8” w/ ARB and 5.29’s
Longfield 30-Spline Gun drilled birfields and 4340 chromoly axle shafts
Aisin manual locking hubs w/ longfield hub gears
Machined IFS hubs w/ ARP hub studs
Heavy wall front driveshaft
Extended breather
Rear: 5:29’s with the factory E-locker (built by ECGS)
HD .120 wall rear CV driveshaft (Rocky Mountain Driveline)
TG Rock Assault housing (Tacoma width)
FROR Full Float kit w/ 4130 chromoly axles
TG Chromoly spindles, wheel hubs, and drive flanges
Custom machined seal adapters
Geniune Koyo wheel bearings, ARP Hub studs
TG 1.5” Wheel spacers
Extended breather
Transfer Case:
Dual Cases
TG Tacoma dual case adapter kit
23 Spline input gear (Stock 2.28)
FROR Transfer case mount (Modified)
Modified Radesign triple stick shifter
Steering:
TG Power Flow IFS steering box
TG Power Flow 1650PSI pump kit w/ cooler and reservoir
TG Hydro Assit ram
Marlin Crawler 25mm steering upgrade kit and billet steering arms
Barnes4x4 Heim Joints
Engine and Performance:
1st Gen TRD supercharger (Rebuilt)
URD 7th injector kit
URD 2.2 Pulley
“Bolted” motor mounts
Relocated fresh air intake
AFE Dry Flow cold air intake
TRD dynamic tensioner kit
Flowmaster Deltaflow 50 series, w/ custom tailpipe
Duralast Platinum AGM H8 w/ custom mount
B&M transmission cooler
2wd T-100 Oil pan and pick-up
Shorter 4cyl Tacoma Radiator
Genuine Toyota Block heater
Genuine Toyota Timing belt and water pump
Brakes:
Front - Tundra 231mm 13wl calipers
FROR Tacoma brake brackets
Genuine Toyota Tundra rotors / pads
TG Extended stainless braided brake lines
Rear disc brake conversion- 1986 4cyl calipers and pads w/ FJ60 Rotors
Adjustable rear proportioning valve
Lighting:
Ebay headlight housings, OSRAM bulbs
Burtman Clear corners w/ LED bulbs
LED Front turn signals
LED Tail lights w/ Superbright LED reverse bulbs
Auxbeam 7” LED 80w round driving lights (three of them)
40" Single row LED light bar (remote controlled)
Rigid Industries Dually Amber D2 driving lights (wired to factory fog switch)
Superbright LED interior dome lights, License plate light
Rear deck/hatch LED camp light
Rocklights – Rigid SRM's and Oznium LED’s
Reverse light - Single Rigid Industries Dually D2 Diffused
Under body reverse lights - Rigid SRM's Diffused
LED Maglite – Mounted to D/S seat
Interior/Electrical:
Custom PRP Daily Driver seat with heat and custom mount
Pioneer AVH-P3400BH headunit
Alpine amp
10" Rockford Fosgate subwoofer
Rockford Fosgate speakers (front and rear)
Sound deadening on all doors and rear cargo area
Plug in USB charging port
Dual USB charging port - switched
Uniden Pro 520 XL CB radio and Wilson 4' flex antenna
SPOT GPS messaging & locating beacon
Garmin GPS w/ Ram Mount
Trailer wiring (7way with rock light and reverse)
Weathertech floormats front/rear
Scangauge II
Camping and “Overland” Gear:
Custom cargo and sleeping platform
Indel B Fridge/Freezer on custom slide out
Kitchen slide out with built in Coleman grill/stove
Multiple LED lights, USB ports, and 12 volt outlets
BOSS 12.1” DVD player in sleeping area
Carbon fiber wrapped rear side windows, side window screens and divider curtain
Low profile roof rack with ARB awning, Hi Lift jack, Splitting axe and chainsaw holder
15 Gallon auxiliary fuel tank with transfer pump
Trasharoo with pine scented trash bags
Exterior / Accessories:
Fender flares and cladding removed, holes filled and body bedlined
Firewall tubbed, front and rear fenders trimmed and enlarged
Toytec 1” bodylift
Clear bra (24” hood/fenders and headlights)
3M Carbon fiber wrapped door posts
Hella Sharptone horn kit
20% Tint on all side and rear windows
AVS In-channel vent visors
Armor / Protection / Recovery:
Custom built Front Bumper
Smittybuilt X2O 12,000 winch w/ Masterpull Superline XD
In-cab winch controller
Custom built Rear bumper
Custom built Spare tire carrier (Version 2.0 in the works)
Custom built Rock sliders
Custom built radiator protector
Custom transfer case skid plate (In progress)
Lil’ Skip gas tank skid plate
Inchworm E-locker guard
Lotus lower control arm skid plates
Custom lower shock bolt protectors
20lb CO2 Tank, tools, recovery gear
Dirtco is offline   Reply With QuoteReply With Quote
