Thread: Jacking Point
View Single Post
Old 11-18-2017, 01:07 PM
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Originally Posted by chopper1 View Post
I have a 2-post floor lift. It fits fine on the frame of my 03 4runner but won't reach back to the rear axle. Can anyone tell me if, when raised from the frame, will the rear axle sag down far enough to damage anything (hoses/wires). If I can't find out from someone who's done it, I'll use chains to support the rear axle and keep it from hanging too low, but it's an inconvenience. Thanks for any advice.
Bill in Oregon
It's fine. I do it all the time. The shocks limit the axle droop, as designed. No wires or hoses will be damaged. If you bring your 4runner into any Toyota dealer for undercar service, the first thing they'll do is lift it by the frame with a 2/4 post lift just as you want to do. Same at most tire shops. The manual specifies the fore and aft side rails as lift points, and says nothing about supporting the axles, because it's unnecessary.
Keep in mind also that those of us who offroad extend the rear axles to full droop routinely. The 4runner wouldn't be much of an offroad vehicle if the brake lines got damaged every time that happened.
Now, if you want to change your rear shocks, you need to be a bit more careful. Once the shocks are disconnected, the axle can droop far enough to stretch the brake lines.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
