Originally Posted by JayRolla
So you pulled good oem injectors and installed used oem injectors? If you got them new for $140 for all 6 they are most likely knockoffs. Many crappy injectors sold as oem brand but the price is a bit low to be true.
I suspect injector issue maybe.
Pulled working OEM injectors and bought new OEM injectors. Thought the price was a little suspect, but they look exactly like the OEM ones that I pulled out.
Ended up having the old OEM ones cleaned and tested by a local shop. All checked out. Just swapped them in. I will check in tomorrow with my results and hopefully solved issue.
Sending the “new” injectors back to amazon next week
