Thread: Salt hack
View Single Post
Old 12-12-2017, 11:09 AM
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Originally Posted by marcus clarkus View Post
Bad for the environment, as others stated. If I had a house with well water I would not want someone spraying gallons and gallons of WD-40 nearby.
It's also attacks some plastics -- Polycarbonate, ABS, I think polyethylene. I'd avoid spraying it in the engine bay or directly on any plastic parts (including plastic trim pieces). It's not a huge deal or something to freak out over, but avoid it if you can -- especially your headlights!
Just a small bit of overspray, not gallons. I hear ya, but at 1,000 miles a week. The tailpipe is the culprit, my WD-40 is a many trillions times less. But someone mentioned mineral oil, that may be a better option, also cause of fumes also when spraying. Hearing problems with Fluid Film swelling bushings swayed me away from that. I'll avoid rust somehow.
Sent from my SM-N920V using Tapatalk
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
