View Single Post
Old 03-29-2018, 06:40 PM
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Originally Posted by Hepar View Post
@theesotericone , you mentioned you were a plumber once? If so, I've got a quick question for you. The hot water outlet is 1/2" and my faucet has fixed 3/8" lines. So, I bought a brass reducer. With a few wraps of teflon tape, it leaked. With no tape, it leaked even more. With SEVERAL wraps of teflon tape, leak finally stopped. Is that in any way normal? I ordered another reducer hoping that's the issue. Or should I just not touch it since there is no leak
Link the adapter you purchased. Was the leak on the 1/2" angle stop side or the 3/8" faucet side?
The 1/2" fitting is NPT and those require pipe dope, Teflon tape, or both. The 3/8" fitting is a compression fitting. The thread count and pitch is different then NPT. Those should never require either tape or dope. There's a rubber seat washer in the sink supply line that creates the seal.
As long as you have the correct reducer and the leak was at the 1/2" side your fine. If the leak was at the 3/8 side you could have the wrong reducer or a bad washer in the sink line.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
