Real Name: Dave
Real Name: Dave
You want the rake, unless the whole suspension is very stiff.
The rake is there because all of the added cargo load goes on the rear springs. When loaded, the truck levels out. If you reduce the rake with a smaller, lighter spring you may have reverse rake when loaded with gear.
You should look at your expected loads and the spring capacity of the rear coil spring you're considering. Do you have heavy mods such as a rear steel aftermarket bumper, a tire carrier or fuel cans loaded on the back? You need enough spring capacity to compensate for fixed mods and added cargo loads, without significantly dropping the rear wen loaded.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
