ECT - electronically controlled transmission. Gives more performance (less gas MPG) by holding gear to higher RPM before shifting. Sounds like it is undriveable as it is - take it in and have it diagnosed properly - 2 folks saying bad MAF would make me swap it out though. How did you clean it - contact cleaner I hope. It is fragile.
When you cleaned the MAF did you also clean the throttle body? It gets black and grease and cloughs up too. They have special cleaner or you can use spray carb cleaner. Thinks like air filter and plugs are normal maintenance items so don't count them toward cost to fix.
'03 Black 4L V6 4x4 SE 4Runner/'03 Navy 4 cyl SE Camry/'05 Phantom Gray Corolla LE/'85 Rust-white 22RE Yota SR5 PU
'57 Black/Red 356 Porsche Speedster CMC Replica
MODS: Silverstars, WeatherTech mats/vent visors/Hood deflector, BORLA dual exhaust, K&N Filter Charger, VVT-I emblem, JDM tail lights, SS rear bumper step, Putco chrome mirror/door handles, Limited lighted running boards, 115V AC inverter, Rosta seat heaters, HomeLink, Michelin CrossTerrains
