View Single Post
Old 07-13-2018, 12:32 PM
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by bradstone View Post
I replaced a seized front caliper, I bleed the fronts the old school way, pump the pedal, hold and crack the bleeder, repeat til no more air bubbles.
Tried the same on the rear but the pedal never drops. The bleed screw is not plugged because fluid comes out into the tube.
Pedal is firm, just as it was before the caliper change. Any tips on how the bleed / flush the rears?
thanks
as they said for the rear, key on and just hold the pedal.
however for the front, or any other traditional brake system, the "pump, pump, pump, hold, bleed" method is no longer the preferred way to do it. the preferred method is ONE pedal push for each bleeder opening.
so, bleeder open, pedal down, close bleeder, pedal up. pause, wait AT LEAST 10 seconds. then repeat until all the air is out.
the reason for this, is the multi-pump method will turn large air pockets(bubbles) into very small, even microscopic bubbles. these are VERY hard to get out of the system. they will adhere to the inside of the hose and just stick there.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
