View Single Post
Old 07-13-2018, 05:06 PM
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Originally Posted by nevada View Post
as they said for the rear, key on and just hold the pedal.
however for the front, or any other traditional brake system, the "pump, pump, pump, hold, bleed" method is no longer the preferred way to do it. the preferred method is ONE pedal push for each bleeder opening.
so, bleeder open, pedal down, close bleeder, pedal up. pause, wait AT LEAST 10 seconds. then repeat until all the air is out.
the reason for this, is the multi-pump method will turn large air pockets(bubbles) into very small, even microscopic bubbles. these are VERY hard to get out of the system. they will adhere to the inside of the hose and just stick there.
This is always the preferred way to do it.
CutthroatSlam is offline   Reply With QuoteReply With Quote
