Originally Posted by Hailmagnet
One has a torn boot so I figure I will just replace both cv’s. What brand should I go with? Will be off reading / camping with this rig so better quality is preferred.
I replaced both mine after my lift with CVJ, they are well priced and you can get better boot options if you need more rugged. I go with the standard and haven’t had an issue. My driver side outer (nearest the tire) tore but I’m thinking it must be from road debris. Usually the ones to tear on our rigs are the inners from the angles after a lift. Link in case you’re interested.
https://www.cvjreman.com/cv-axles/
