Originally Posted by rhoyneriver
Wow, this is a great writeup and thanks for updating the pictures! I'm not very good with any wiring projects, but I may have to give this one a shot! I love the clean OEM finish at the end.
edit: did you disconnect the neg terminal on the battery before starting? or is that not necessary since you're unplugging that white power port plug before splicing?
Thanks for your kind words.
Re the battery, no, and it was fine, probably b/c the power is unplugged as you noted. But obviously ymmv and it’s always safest to disconnect the battery.
meltdowner
, 16g should be fine, pretty sure that’s what I used.
