If you're lazy, it will simply cost you more money! :awais:
You can get a SC12235 cable for iPod control (if the HU supports it), and a SC12337 cable for the Aux input. Both plug right into the back of the HU, and the other end plugs right into your auxillary device. Can't be any easier! :headslap:
Here are a couple of links to past ebay auctions for each cable. The first one
HERE is the SC12235 iPod cable.
The next one
HERE is a similar cable, but for the Aux input instead, #SC12237.
Note the seller is the same for both cables (
billc41 on ebay), but there aren't currently any for sale of either one.
Each cable will cost about what the HU cost though, so if you're going to buy a HU and BOTH cables, you might be better off with an aftermarket HU or a better Scion Nav HU. Hope that helps you out a little more.
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners,
WeatherTech window deflectors, Silverstar Ultra headlights,
TaskLED Dome lights, Red & White LED maplights,
LED tails & 3rd brake light, 35% tinted front windows,
TrueFlow air fliter, hardwired V1,
Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
