View Single Post
Old 02-05-2019, 06:23 PM
4Reak Show's Avatar
4Reak Show's Avatar
Originally Posted by Bumbo View Post
@4Reak Show
I really try not to get involved with other peoples wiring setups, design, and engineering... but...
1) What is the size of the wire you are using
2) What is the length of the longest wire run
3) What size fuse did you select (500A?)
4) What is the design load (max load for the winch component on the spec sheet)
I appreciare that but I'm sincerely trying to help people.
1) wires are the same size that came with the winch. Something around 2 gauge or 1/0.
2)Same length that came with the winch, about 5.5-6'
3) correct. 500a ANL Fuse
4)maximum winch draw is advertised at 435 max. Probably a lot less during lighter pulls. But 435 is advertised as the most it's capable of pulling
