View Single Post
Old 06-07-2008, 11:25 AM
POPSRNR POPSRNR is offline
POPSRNR is an unknown quantity at this point
Originally posted by 96dcmss
should be a relay, or EFI fuse to disable fuel. Just unplug and remove the coils. You have to take the plugs out anyway.
Thanks for the reply!
After posting, I remembered I had the shop manual in PDF format and in case anyone else has the same question, this is what the manual says:
10. INSPECT COMPRESSION
(a) Remove the V−bank cover sub−assy.
(b) Remove the air cleaner hose assy.
(c) Disconnect the throttle control motor connector.
(d) Remove the 8 ignition coils.
(e) Remove the 8 spark plugs.
(f) Disconnect the 8 injector connectors.
Removal of the EFI fuses, there are several, would probably accomplish the same thing.
POPSRNR is offline   Reply With QuoteReply With Quote
