View Single Post
Old 04-09-2019, 12:34 PM
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Originally Posted by 4daddy View Post
Having same problem with top nut rusted on shock. Stuck cant remove. Bent shock back and forth but will not break. Where exactly do you cut with the sawzall? I cant imagine there is enough space to cut on top of the shock mount to get a blade in there so I am at a loss... Help
I cut right through the rubber bushing and shock shaft above the top of the frame rail on 4runner. On my Tundra they were also seized on but there was enough room to make a slit in one side of the nut then rotate the shock 180 degrees and make another slit, this cut the shock nut in half so it could just be tapped off with a flathead. Both methods ruin the shock and mounting hardware, install new with your new shock.
blackoutt is offline   Reply With QuoteReply With Quote
