Originally Posted by Serge627
You want your sway bar to remain parallel to the ground. So with a lift and stock end links it will cause your sway bar to angle down. You then need to extend the end links to get the sway bar back to parallel.
Okay gotcha, so I take it was in the amount of lift you want to increase the link length? Is it as simple as for every inch of lift you add an inch to the link?
