Thread: Brillos Builds
View Single Post
Old 09-16-2019, 09:37 AM
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Last Man Standing View Post
Brillo,
Great Pic's and info on frame repair!
I noticed you had a section of repair that had a arch pattern
in that area of the frame, how did you cut that pattern and are
you using all 1/4" plate for these repairs?
I took your advice and purchased a Fluid Film spray gun with a
long extension ( 32" ) for inside the frame coating. Time to save a
few pennies and stop buying those spray cans. I also ordered a can
of the FF with the brush for touch up spots such as my back bumper.
I am very pleased with the rust on the frame results after applying this
stuff!
Keep up the great work showing us your methods as I will try to do the same on my
end for whatever I do as well where it can help the community here on T4R......
LMS
I use 1/8 plate. As 1/4 plate is entirely too think and hard to work with. My patterns are made with just card board. Then I trace it out the the steel and cut it out.. I mostly leave a 1/4 to 1/8 gap in the bottom so i weld the plate to the frame and keep it all in the lip.
I use I will verify but from memory 5.5 inch 1/8 bar stock, 3.5 inch 1/8 bar stock and 2.5 bar stock steel. the 2.5 is my bottom of the frame and the other two sizes are my sides.. Middle section is 5 inch.
when an area is completely rotted. I cut it out and plate the inside first. Once that is completed. I will put a plate on the outside was well and weld it all together. This is very common in the Arch areas as they mostly rot out first. By sealing this all up. Not only we get a super strong frame. We get rid of all the holes in the frame. So the paint and fluid film cant go anywhere and just protect the steel. Should make the frames last almost forever. Regardless of the areas they are in. :-]
